Timing Marks (Cam & Crank) Timing Belt
Old Aug 26, 2006 | 03:29 PM
Soloracer's Avatar
Default Timing Marks (Cam & Crank) Timing Belt
I'm in the process or performing the 105,000 mile service on a 2003 V70 non-turbo. I see the marks on the cam sprockets (on the outside) but nothing on the inside to align with at the head. I believe the cam sprocket markes are to be vertically aligned with the engine but not sure, the belt slipped and I lost my cam reference. There is a "V" on the pulley that appears to be at the bottom and what looks like a mark on some device behind the pulley which seems to align with a small casting mark on the block. My belt slipped with I was taking it off and I am somewhat confident the crank marks are 'right' but I am not sure how the cams are referenced from.
Thanks for any and all support or advice.
Erik
Old Aug 26, 2006 | 04:43 PM
Default RE: Timing Marks (Cam & Crank) Timing Belt
For the Cam marks the top timing cover is the refrence for the marks. Slide the cover on and line them up.
HeadDragon
Jun 12, 2011 10:18 PM
cdlahoward
Jun 12, 2011 05:03 PM
phillip gotts
Aug 18, 2010 11:01 AM
Carbuff
Dec 28, 2009 06:24 PM
ebrobb
Aug 10, 2006 08:25 PM
