Timing Tool
Old Apr 1, 2008 | 07:09 AM
Blue Streak's Avatar
Default Timing Tool
Hi.
Please can any one tell me where I can get the timing tools required to change the T/Belt on a V70 2002, (Crankshaft Holding tool, Serpentine tension release tool etc.
Old Apr 1, 2008 | 08:02 PM
Default RE: Timing Tool
You don't need them to do the timing belt.
Old Apr 14, 2008 | 12:57 PM
sh02V70T5's Avatar
Bluestreak,
Just did this last week. Thought i'd need special tools also.
You don't need the special tools. The serpintine acc. belt uses a T60 torks. The big nut on the crank can be removed with an impact wrench- I used a 1/2" electric and a heavy duty 30mm socket, it worked fine. You have to "finesse" the harmonic balancer pully to get it off. I used some liquid wrench and lightly tapped the balancer with a hammer until it worked loose. Make sure you set the timing belt tensioner correctly. The adjuster uses a 6mm allen wrench.
Oh, and leave the top cover of the timing belt in place. you need the marks on it to make sure the cam gears are lined up.
Steve
morrisamazon53
Aug 29, 2010 09:01 PM
JoJoDaClown
Jul 14, 2009 11:00 AM
rcsoundn1
Sep 9, 2008 01:48 PM
junkprospector
Feb 23, 2008 08:36 AM
BillA
Jan 23, 2008 06:27 PM
