Trans
did it work before the fluid change?
start by checking the fluid level (using the correct procedure - there's vids on youtube). what was done for the fluid change ie drain/fill, flush by removing the cooler lines etc? Do you know what kind of fluid was used during the change (see your owners manual for the proper fluid specs for the AWD (I believe its JWS 3309)
nortons
Feb 22, 2015 11:14 PM
ded137t5r
Jun 10, 2012 07:40 PM
Eric's Hot Rod Shop
Jul 14, 2011 08:26 AM
