Transmission cooling lines, how to disconnect
Old Feb 20, 2009 | 03:07 PM
rmendoza's Avatar
Default Transmission cooling lines, how to disconnect
Hey guys,
I am changing my radiator in my 98 V70 (finally! ; I am taking some pics), and I am at a loss as to how to disconnect the transmission cooling lines. I see they have some sort of easy connector or snap-on connector (green), but I don't want to mess it up if it requires a special tool or something. Any help is greatly appreciated, preferably before sundown . Thanks in advance.
P.S. I will report back when I am done, and I will post pics.
Old Feb 20, 2009 | 06:46 PM
rmendoza's Avatar
Thanks a lot guys. I am sorry I didn't write an update sooner, but I was toiling away with the radiators.
I have it almost all back together. The only thing I am missing is making the top part connections and putting the retaining bolts back on, the ones right next to the headlights. I have to confess that I took a shortcut with these bolts: after trying for several minutes to figure out how to get at them, I figured I wouldn't hurt anything if I drilled two holes through the plastic housing of the headlights . It worked! It made my life a lot easier. They don't look too bad, as I took a carpenter's bit, the kind you use to make big diameter wholes in wood, and the holes ended up looking almost factory made.
Now my question is this: once I have everything put back together, how should I add the coolant and water. Also, should I add more tranny fluid, as it only dripped a little bit?
P.S. I'll tell you, even though this job is a little tricky, it's definitely worth the effort to save the almost $400 in labor that the dealer wanted to do this.
Old Feb 20, 2009 | 09:47 PM
The coolant goes in through the coolant bottle.
Check the tranny fluid level and see if it is low now.
Old Feb 20, 2009 | 10:10 PM
rmendoza's Avatar
Default update
All done. However, there is a leak somewhere. It seems to be coming from the water pump area, but I suspect it's dripping down from the thermostat housing (which I just replaced, due to my breaking it ). I will report more on this tomorrow, as it's already pretty dark and I am tired.
In the meantime, thanks again for your tips. I'll keep you posted.
Old Feb 20, 2009 | 10:11 PM
I hope it is a nice and easy fix.
Old Feb 21, 2009 | 12:29 PM
rmendoza's Avatar
Talking Dumb mistake!
All is well, at least with the radiator. I am embarrassed, but here I go: I had forgotten to put in the thermostat, with the accompanying gasket.
In any event, I put it in, and also used some thermostat silicone: no leaks now!
Now I have another problem: the oil dipstick handle broke off. It seems non stop with this car! (I almost want to get a Toyota) I will get a new dipstick Monday.
P.S. One last question: is it okay to use the thermostat silicone, or was that overkill?
P.S. #2 I forgot to say that even though it was a little tricky and it required patience, doing the radiator wasn't as bad as I thought it would be. At least I know it wasn't worth the $400 bucks that the mechanic wanted to change it.
Old Feb 21, 2009 | 06:34 PM
The silicon was a little overkill but it will be fine.
Old Feb 25, 2009 | 01:41 PM
rmendoza's Avatar
My coolant-out-of-the-reservoir-cap problem is back. Damn car. I thought I had gotten past that problem. The car overheated for a few seconds and I took it to a reputable Volvo mechanic and said that it was only an air pocket. But the coolant still spills out through the cap, so I am still suspecting a BHG.
Old Feb 25, 2009 | 02:11 PM
rmendoza's Avatar
I read somewhere that sometimes the water pump or the impeller in it can go bad, and cause blockages, which result in coolant spilling out of the reservoir.
I ask this not because I am trying to avoid the possible HG problem, but rather because the mechanic said he didn't think it was a HG, as it doesn't spill coolant when cold or even all the time when warm, only when under load. Even when I park it and leave it running, the coolant remains the same; it's only after driving for a little bit that this happens. I am going nuts.
Old Feb 25, 2009 | 07:59 PM
You might want to do a quick block test to make sure the HG is good.
Old Feb 25, 2009 | 09:11 PM
rmendoza's Avatar
Thanks for the answer Tech.
The problem is, no frigging auto parts store sells block tests where I am (Tucson). I already went to three or four, and they look at me like I am speaking in tongues. I will call around tomorrow.
Old Feb 25, 2009 | 09:35 PM
Ok keep me posted if all else fails I will find a kit online that you can order.
Old Feb 27, 2009 | 03:18 PM
rmendoza's Avatar
Ok, it's official, I have a blown head gasket.
Now the question is, how expensive is it to fix this?
Is it something that a moderately skilled person could tackle? Is there a write up or how-to for head gaskets? Do you think it might be better to junk the car or swap the engine instead of doing the HG?
Thanks for all your help guys. I look forward to your response.
Volvo_1997
Oct 18, 2009 12:37 AM
xjflexer
Mar 26, 2007 08:23 PM
sdat1333
Feb 10, 2007 10:02 AM
ludeless
Nov 15, 2006 03:33 AM
Dads850
Aug 28, 2006 09:04 PM
