Battery disconnect and Radio Code?
Old Mar 21, 2007 | 01:15 PM
xjflexer's Avatar
Default Battery disconnect and Radio Code?
If I disconnect the battery to reset all of the learned memory in my R, will I need the radio code afterwards? I cannot find the code in my owners manual as of yet, and I don't want to screw myself.
Thanks guys!
Old Mar 21, 2007 | 01:34 PM
info2x's Avatar
Default RE: Battery disconnect and Radio Code?
You will need your radio code. You need to get it from the dealer.
[align=left] [/align]
Old Mar 21, 2007 | 02:11 PM
Psaboic's Avatar
Yep, you will need to take the VIN number of the car along with proof of ownership (title or registration) to your dealer and they can look up the code for you. At least that is the way it worked for me
Glenn
Old Mar 21, 2007 | 04:30 PM
billofdurham's Avatar
Depends on the dealer, some will do it over the phone. Just in case the radio is a replacement, you should also have to hand the radio serial number as they can do the job from this.
This is a free service. I have heard of some dealers trying to charge.
Old Mar 26, 2007 | 08:23 PM
ubergeek's Avatar
When you go to the dealer DON"T go the the service department.
Head right in to the parts department w/ either registration or title.
They (most) will run it over to the service department for you. No Charge.
I have done it both ways to see what happens. Most want you to pull intot he service area so they can charge ofr a service call.
amadeo_244
Nov 3, 2012 05:55 PM
Mr. G
Feb 6, 2010 09:11 AM
woodkayakr
Feb 26, 2009 02:52 PM
The Edge
Oct 19, 2008 01:36 AM
