transmission fluid change
Old Oct 17, 2007 | 09:49 PM
tanjung66's Avatar
Default transmission fluid change
I am planning to change transmission fluid on my 99 v70 this weekend. I got DEX III fluid from the local part store.
My questions are:
1. Can I use any DEX III fluid?
2. Is there some kind of filter that I need to change?
3. Should remove the pan to drain the fluid or is there plug bolt?
Thanks in advance.
Old Oct 18, 2007 | 05:26 PM
Default RE: transmission fluid change
It all depends on your transmission which one you have.
Read through this post.
https://volvoforums.com/m_35817/tm.htm
Stratoblaster
Sep 2, 2024 11:18 AM
AustinPower
Nov 11, 2008 07:43 AM
WHOISBIGMAN
Nov 11, 2006 02:37 PM
novablue69
May 12, 2006 09:05 PM
