V70 - Front end growling and vibraton????
Old 07-16-2009 | 05:43 PM
jpmarley's Avatar
Default V70 - Front end growling and vibraton????
Hi, my '98 Volvo V70 turbo w/ 154,000 miles has had a growling sound in the front end for awhile, it used to be faint and bearable, and driveable, speed really doesn't make a difference, except for it doesn't start until after 25 mph and then it is basically the same all the way up to 60 mph. At first I thought it was a wheel bearing and now I'm not so sure, turning to one side or the other does'nt make much of a difference and now there is a moderate vibration involved. The tires are newer, brakes and rotors are good. Could it be the transmission? or are both front wheel bearings shot?
Old 07-16-2009 | 09:44 PM
My guess would be wheel bearings.
Old 07-17-2009 | 02:06 PM
08capsfan08's Avatar
i have an 02 V70 . . . had the same symptoms as your 98 and turned out to be the engine mount and engine mount bushing causing the vibrations (that kept getting louder in time until it was so bad it stalled the engine)
jewrican
04-23-2012 09:22 PM
scootr65
02-21-2010 09:41 PM
mgacarnut
05-09-2009 12:19 AM
Metcalfe
04-04-2009 10:20 AM
Quick Reply: V70 - Front end growling and vibraton????
