V70 low beam stopped working
Old Dec 6, 2009 | 09:37 PM
byoung2650's Avatar
Default V70 low beam stopped working
Both low beams quit working at the same time on my 01 V70. I installed 2 new bulbs with no luck. I changed the 2-10amp fuses in the cockpit and engine compartment, with no luck. There are no error messages....except for "bulb position failure" which has been on long before low beams stopped working. High beams and all other lights work fine. Any ideas??
Thanks,
Brian
Old Dec 6, 2009 | 09:58 PM
There is a shunt under the dash in the main computer that get a bad connection from time to time.
Old Apr 23, 2010 | 06:07 PM
mikalle76's Avatar
Where is that shunt located under the dash on the computer?
Old Apr 24, 2010 | 07:49 AM
If you remove the lower dash panel(2 t-25 screws) then remove the panel. Then look over by the hood release and up some. You will see the computer up there. There is a tab you will need to move to swing the cem then it will drop down and then you can see the shunts.
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
DaveDog2010
May 17, 2021 09:00 AM
volvo40_2k
Jul 28, 2009 09:18 PM
Mr.Chips
Aug 5, 2008 02:52 PM
adame780
Aug 26, 2005 08:30 PM
