V70 - power steering and brake fluids
Old Nov 2, 2005 | 02:04 PM
azeezn's Avatar
Default V70 - power steering and brake fluids
Folks, I have a '98 Volvo V70 AWD. Have taken couple of days off to do some maintenance work on my car thru this weekend. Have few questions:
- flushing old power-steering fluid and thinking of refilling with Mobil ATF D/M. Is it the right fluid? Manual says Dexron Type ATF
- what quantity would I need? Manual does not mention this.
- flushing brake and clutch fluid and refilling with Dot4 or Dot4+ brake fluid. Pls suggest a brand?
Thanx! Appreciate your help and time.
Old Nov 2, 2005 | 08:36 PM
Default RE: V70 - power steering and brake fluids
The trans fluid will be fine. If you are flushing it then I would run about 2 quart through it. So pick up 2 to 3 quarts.
The Brake fluid doesn't really matter about brand. But if it matters to you I use Castrol GTX fluid.
If you are flushing them good then either a couple of the small bottles or one of the big ones.
TacklaNHL
Dec 12, 2010 10:02 PM
boiseone
Sep 13, 2010 11:30 PM
holtmant
May 31, 2007 01:58 PM
blase
Jul 29, 2005 01:03 AM
