V70 Resonance Vibration at 2-2.5K RPM
Old Sep 11, 2005 | 03:12 PM
Hilton's Avatar
Default V70 Resonance Vibration at 2-2.5K RPM
Can anyone tell me if my 2004 V70 2.4 is different to others. After just 4500 miles from new, I can now sense a slight resonance noise between 2000 and 2500 rpm after which it dissappears. I have a feeling I read somewhere that this is a V70 symptom which can be cured. Any advice welcome.
Old Sep 11, 2005 | 04:56 PM
Default RE: V70 Resonance Vibration at 2-2.5K RPM
Does it only happen when driving or does it still do it while in park?
Old Sep 11, 2005 | 06:24 PM
Hilton's Avatar
Strangely, in park the engine seems to be smooth to run up throughout the entire rpm range. I've only noticed the change in background noise when on the move. There are no other adverse symptoms.
Old Sep 11, 2005 | 08:27 PM
Im thinking either a bad engine mount or a bad tire.
Old Sep 12, 2005 | 06:29 PM
Hilton's Avatar
Thanks Tech - I'll try to narrow the noise down further . I recall someone had the dealer adjust the exhaust system heat shield but I may be confused with another fault. Regards,
Old Sep 12, 2005 | 08:51 PM
That is also possible I have seen that before as well.
2003volvov70
2001-2013 model year V70
Mar 31, 2013 03:30 AM
ocean238
Apr 17, 2008 06:20 PM
Viraaj
Nov 15, 2006 05:35 PM
violinist
Nov 27, 2004 09:46 PM
