v70-t5-1998
Old Sep 3, 2005 | 02:23 PM
mhanson8's Avatar
Default v70-t5-1998
HI,I NEED TO GET A SERVICE MANUAL FOR MY RED T5. INEED TO FIND OUT WERE THE CRUSIE
CONTROL IS CONTOLED FROM OR FUSE.MHANSON
Old Sep 3, 2005 | 02:27 PM
Default RE: v70-t5-1998
You might want to see if your battery was leaking Acid.
If the battery leaks acid it might have eaten on of the lines for the cruise control.
The cruise motor should be located under the battery tray.There should be a hose that runs from the motor under the battery tray and around the body.They are known to have a hole near or under the battery tray.You can stick a peice of rubber hose ove the plastic hose to fix it.
kraken
Apr 8, 2015 12:30 AM
RonNaismith
Feb 28, 2005 07:24 PM
mycarl
Feb 16, 2005 05:56 PM
Mcgurk
Dec 16, 2004 09:57 PM
Melhunt
Oct 5, 2004 10:04 PM
