Is the V70r steering column shroud compatible with V70 GTL?
I just bought a used 98 v70 GLT. There are only two issues, that I could use some help with.
1) The car didn't come with a shroud on the steering column. I found one on eBay for a 98 V70R. Is this compatible with the V70 GLT? The eBay seller does not know.
2) The interior panel for the back door is warped so it does not clip back in. It rattles quite a bit. Can you point me to a vendor that sells these?
Any help would be appreciated. I'm usually pretty good with web searches, but can seem to come up with much.
Thanks
John
Thanks
John
