Volvo V70, 2.4 Vibration at acceleration
Old Jun 6, 2007 | 02:04 PM
perevod13's Avatar
Default Volvo V70, 2.4 Vibration at acceleration
Hi, my 2001 V70gets quite bad vibrations at 45-65 miles, especially when accelerating peaking at about 55 miles. If it goes faster, these vibrations calm down.Even when completely lifted from the ground,and the wheels taken off, the vibration is still present. They triedpropping up the enginea bit assuming that the mounts are bad butto no avail. It looks like shafts are a bit bent and bearings are not in the top shape either (140,000 miles) but the vibrations are too strong to be caused just by these factors.What else do you think it can be? Thank you!
Old Jun 6, 2007 | 10:10 PM
Rickc10ny's Avatar
Default RE: Volvo V70, 2.4 Vibration at acceleration
"It looks like shafts are a bit bent and bearings are not in the top shape either (140,000 miles) but the vibrations are too strong to be caused just by these factors. "
Based on what theory? My sister-in-law had the exact same issue with her 2002 V70 , after the dealer jerking her around and her wasting money rebalancing the tires and replacing a motor mount ,it was found to be a worn (dry) cv joint
Old Jun 7, 2007 | 10:54 AM
perevod13's Avatar
Thanks a lot! What you said definitely makes sense, but the CV joints seem OK. They are firm, they don't make any noises and it looks like they are lubed. I wonder what else can cause such vibrations? Thanks again!
crashin
Mar 28, 2022 03:05 PM
volvorecycle
Jul 22, 2015 07:44 PM
ocean238
Apr 17, 2008 06:20 PM
jdjayakaran
Dec 19, 2007 06:09 PM
Joey P.
Jun 18, 2007 08:04 AM
