volvo v70 2.5 10v not spark
Old Jul 26, 2011 | 07:00 AM
volvo v70 25's Avatar
Default volvo v70 2.5 10v not spark
hi all this is the first time i have used this so i hope that you can help me
my head gasket went on my car so i took the cylinder head off to replase the head gasket i put it all back togtougther started the car up and it san fine terned it off then went back to start the engine up but would not start i had a look under the bonnit and there is no spark could any of you help me with this thanks
Old Jul 26, 2011 | 12:52 PM
If you replaced the head gasket and started the car you are ahead of me. However, did you check to make sure the cam sensor didn't come loose or something? What have you done so far to cure/trouble shoot the problem?
Old Jul 26, 2011 | 05:19 PM
hi i have lookes at all the cables andplugs i have took all the spark plugs and they do not spark but what i carnt work out is it started up ok then would not start agane
Old Jul 28, 2011 | 03:19 AM
sorted i have got it up and running it waas the crank shaft sensor after all that
wantheman9884
Oct 24, 2012 05:05 PM
Touristica
Feb 11, 2010 05:59 AM
ped5570
Jun 16, 2008 08:34 AM
VolvoJim
Oct 25, 2007 01:02 PM
ocean238
Sep 29, 2007 09:33 AM
