volvo v70 running ruff after feul fill up
Old Jan 13, 2009 | 09:00 PM
volvovolvov70's Avatar
Default volvo v70 running ruff after feul fill up
my wife filled her car with super unleaded and a container of dry gas earlier today.
the started running very rough and would not go over 25-30mpg.
she drove about 1 mile to our normal service center.
i meet her there to pick her up
i started the car and it seemed to run fine.
the mechanic said it was probably a little water and to not worry
these are the codes i got outwith my friendsobd2(p2101, p1651, p1610, p2101)
any ideas???
Old Jan 13, 2009 | 09:11 PM
Default RE: volvo v70 running ruff after feul fill up
I would check the evap valve. They commonly go bad and run bad like that after it is filled up.
Old Jan 14, 2009 | 08:15 AM
thanks for the advise.
i will check tonight.
Old Jan 14, 2009 | 08:17 AM
i tried searching for evap valve cleaning or replacement.
could you give me the quick run down.
thanks for any help you give provide.
Old Jan 14, 2009 | 09:45 AM
The evap valve is mounted in the cooling fan on the drivers side. It has 2 hoses and 1 electrical plug going to it.
I would remove the valve and see if you can blow through it both ways. If so it is bad.
If it only happens once in a while it might be sticking open. You can try cleaning it with carb or brake cleaner and see what happens.
Old Jan 14, 2009 | 10:01 AM
wow,
thanks for the quick response and the great advise.
Old Jan 14, 2009 | 10:06 AM
Your welcome anytime.
dtech13
Jun 22, 2014 01:47 PM
Rickford
Oct 15, 2010 03:02 PM
89irocz
Jul 30, 2010 10:21 PM
csigler
Aug 1, 2009 01:01 AM
kapelewski
Feb 16, 2009 09:49 AM
