Volvo v70xc
Old Dec 24, 2011 | 12:40 AM
jiml100's Avatar
Default Volvo v70xc
I have a bad cv joint I hope... It now shakes at low rpm, when you apply the brakes then it really shakes'...., help does it sound like my cv joint ?
Thanks for any help
Old Dec 24, 2011 | 06:42 AM
Georgeandkira's Avatar
Hello, The "test" I've read about and seen done involves driving your car in the tightest circles you can. Leave the windows open and pick a parking lot with a brick wall if you can so you can hear the CV joint clicking. Other tests I don't know. Kira
Old Dec 25, 2011 | 05:48 AM
Wwildman's Avatar
I need a little more info .
1. Does it shake a low R.P.M on take off and is it the whole car or the steering wheel?
2. The shaking while braking sounds like warped rotors.
I would look the whole vehicle over on the drive train .
Check to see if there is a bad tire somewhere ,see if you have any up/down play and one of the axles also check all motor mounts .
BC1978
Mar 3, 2009 01:50 PM
ruazor
Nov 30, 2008 07:22 AM
jklenk
Aug 18, 2008 12:26 AM
01v70xc
Dec 16, 2004 10:11 PM
