What Is a Position Light???
Old Nov 10, 2008 | 06:40 AM
redheadskier's Avatar
Default What Is a Position Light???
OK - got the headlight replaced this weekend (husband still grouchy - tore his hand up trying to get in there)
I still have an intermitent error message about POSITION LIGHT FAILURE (atleast it doesn't say Multi Bulb failure anymore)
Funny thing - when I take the car to the carwash (when they do the interior - windows etc) the light will then go out so I am sure there is a loose connection (maybe)
But I can't figure out what light it is..........[&:]all the rear lights work when I step on the brake, as do the signal lights, etc
Old Nov 10, 2008 | 07:44 AM
Default RE: What Is a Position Light???
Position light is one of the parking lights in the back of the car.(tail light)
Old Jun 25, 2009 | 09:01 AM
Sssnake's Avatar
Default Locating Your Position Lights
I have found that while your side markers and technically "position lights", the most likely cause of your intermitted "BULB FAILURE POSITION LIGHTS" message is a loose bulb under one of your sideview mirrors. You can access these bulbs by pushing the inner-most side of the mirror in as far as it will go and then using a long screwdriver (and flashlight so you can see what you are doing), push the "tang" to release the bulb housing.
dcb07
Mar 11, 2010 01:41 AM
RedBrick
Oct 1, 2006 11:28 AM
howardr
Jun 7, 2006 02:41 PM
S60T5
Mar 24, 2006 02:32 PM
dreamcars80
Mar 28, 2005 03:04 PM
