wind noise:
Old Jan 7, 2014 | 06:13 PM
wcrowder's Avatar
Default wind noise:
have a 2008 V70, 3.2l with 65,000 miles.
I have a wind noise problem. I hear it slightly inside the cabin. If I roll the passenger window down or open the sunroof and drive 25-35 mph i can hear a whistle. Door seals look good, window seals seem good as does the windshield screen. I am wondering if there are any obvious places for me look or inspect for a air leak. Any insight would be appreciated.
Old Jan 7, 2014 | 09:33 PM
Let me get this straight... when you roll down a window or open the sunroof, you hear wind noise?
Old Jan 7, 2014 | 10:50 PM
wcrowder's Avatar
Correct. But its not the same sound I hear when I roll the other windows down. Its more of a whistle. I can hear it with all of the windows up, too, just not as loud. It sounds like a high pitched whistle, not wind as you might expect to hear with an open window.
Old Jan 7, 2014 | 11:02 PM
gdog's Avatar
Does the noise go away at higher speeds?
Has the windshield been replaced recently?
Does turning the interior fan on/off make any difference?
Old Jan 7, 2014 | 11:41 PM
wcrowder's Avatar
From 0-20 there is no noise. 21-40 it whistles. Above 40 no whistle.
Windshield...I cant say for sure. I just bought the car a wee ago. I inspected it and seems to be very snug.
inside fan speed does not affect the whistle.
Where else can I look, door handle or wheel well? What is a good method for isolating such a sound or is this a guessing game?
Old Jan 8, 2014 | 09:32 AM
Could it be coming from the motor?
Old Jan 8, 2014 | 09:59 AM
wcrowder's Avatar
The motor? Maybe, but I only hear it if i am moving. If I am neutral and rev the engine, no noises. I am fairly sure it is a gap in a seal. But i have inspected the obvious ones. I was hoping others had come across a similar noise with a solution.
Old Jan 8, 2014 | 07:15 PM
wcrowder's Avatar
Located it. It is a crack on the lens on the passenger side rear-view mirror. I ordered a new one...any idea how I can open that mirror up?
Old Jan 8, 2014 | 07:58 PM
gdog's Avatar
Glad you found the problem, but what's a mirror lens? You mean the mirror glass? And how do you know that's it?
Old Jan 9, 2014 | 07:30 AM
wcrowder's Avatar
the plastic turn signal bulb lens. If I cover it the whistle stops. I siliconed it and its fine. But, that is a temporary fix. I'd like to replace the lens.
speedster77
Oct 29, 2007 11:03 AM
Niel
Aug 18, 2006 03:20 AM
mjv4998
Mar 22, 2006 01:44 AM
k9brutus
Sep 11, 2005 09:39 PM
Steamroll9
Aug 1, 2005 04:55 PM
