Windshield Wiper out of whack
Old Jul 24, 2008 | 12:59 PM
96 960's Avatar
Default Windshield Wiper out of whack
The driver side wiper arm on my V70XC AWD Wagon is out of whack. In the stop position it sits about four inches from the bottom of the windshield. Running, it goes just off the windshield. Took the nut off the arm but the arm is not budging and I'm afraid to force it. On my 960 it would just loosen the bolt and turn the arm to the postion I wanted. Not working here. What am I doing wrong. HELP
Old Jul 24, 2008 | 02:43 PM
rules's Avatar
Default RE: Windshield Wiper out of whack
Haynes says you should undo the nut, tap the wiper arm slightly to loosen bond and then using a rocking motion to get it off the spline. The scary part is that they suggest using a puller if that does not work. I see something breaking
Old Jul 24, 2008 | 03:15 PM
96 960's Avatar
Yeah! I see something breaking also. This thing is really stuck. I sprayed WD40 on it and will let it sit for awhile to see if it loosens up. Thanks.
Old Jul 26, 2008 | 08:42 AM
Put some pressure towards the windsheild by the hinge point and it should loosen it.
rspi
Jan 11, 2014 06:22 PM
Genomachino
Apr 15, 2013 09:22 PM
Dr.JellyFinger
Dec 17, 2011 02:39 PM
95pimpwagon
Jan 20, 2006 01:09 PM
Mr. T
Jan 30, 2005 03:17 PM
