HVAC Issues (air blower)
Old 08-06-2021, 10:17 AM
redlight114's Avatar
Default HVAC Issues (air blower)
2017 XC60, 46K miles
Anyone else with this problem?
Occasionally (not often), air flow will drop significantly lower using AC, even while on highest blow setting. It gets really loud behind the console with the fan blowing, but very little air comes out of the vents. Like the vent "steering" mechanism gets stuck out of place. Usually takes turning the car off for a period of time for it to return to normal. Seems to only happen on road trips. Even when turning AC off, the air flow remains low. Frustrating because it can get pretty sweaty driving on hot days while this problem is happening.
Took it to local dealership, and they recommend I need to replace the AC Evaporator at ~ $1700! Not convinced that is the problem...I never get hot air...always cold, it's just the air flow.
No obstructions in cabin filter.
Thanks for any info!
Old 08-06-2021, 12:46 PM
Originally Posted by redlight114
air flow will drop significantly lower using AC, very little air comes out of the vents.
Not convinced that is the problem/
Your Ac evaporator is probably freezing up, filing with ice, reducing air flow, until a compressor off period allows it to thaw. Impossible to duplicate for a shop, unless they take your car on a road trip. Evaporator freezes up because the pressure is too low. Low refrigerant is a common cause - however a year or two ago someone mentioned a software update that Volvo put out to solve this problem for many others were having it also.
A new evaporator is not the solution - although if the refrigerant is low and causing freezing, the system WILL be properly filled after a new evaporator installation and might solve the problem!
Stress this only happens on road trips after driving for an extended period of time at the NEXT dealership service department you try. And ask about the software update that was solving this a couple of years ago.
Leaving the fan on high with the ac compressor off will clear the ice quicker.
redlight114 (08-06-2021)
Old 08-10-2021, 09:56 PM
E-Volvo-ing's Avatar
hoonk, I think you are correct. That was my first thought as well.
Rob Thorp
10-29-2020 05:19 PM
louisejohnsen
11-06-2013 07:12 PM
majorcode
06-23-2013 10:29 PM
diehardgator1
09-03-2011 10:57 AM
brisk8
06-23-2007 08:11 AM
Quick Reply: HVAC Issues (air blower)
