Blind Spot Indicator for an XC60
Old Sep 3, 2013 | 08:56 PM
JBxc60's Avatar
Default Blind Spot Indicator for an XC60
Is it possible to have this added on after the fact? I wouldn't mind adding to just the driver's side if I could. At the moment, I replaced the standard US driver side mirror with an EU mirror which, as standard equipment, is slightly convex along the outer edge and helps eliminate the blond spot but having the electronic version would be great. Has anyone added it after the fact?
Old Sep 3, 2013 | 09:15 PM
ES6T's Avatar
It is not available as an add-on, if I remember correctly.
Old Dec 5, 2013 | 08:57 AM
Blownby's Avatar
Correct. Vehicle has to come from the factory with BLIS installed.
Also,unless you have the new radar based system,the camera based system isnt that great. Rainy,cloudy,dark and dim days,snow conditions,direct sunlight, the system does not work 100 percent.
hgiblon
Volvo C30
Jun 27, 2015 10:04 AM
don in denver
Jun 9, 2014 09:54 AM
vrhs2011
Sep 8, 2012 12:26 PM
wicked96rs
Jan 23, 2011 07:33 PM
air force rascal
Mar 5, 2009 09:55 PM
