Brake pedal fade and high pressure at start-Normal?
Borrowed the Mrs. 2017 XC60 T6 10k miles, and could not start because the brake pedal was unable to be pressed far enough to activate the starter. With a lot of pressure, and a good 5 seconds, the pedal will fall far enough to trigger the start sensor. Driving wise, aside from a slight shudder braking at low speed stops while turning, everything feels fine. But then at stoplights, moderate pressure will allow the pedal to go to the floor. I told her to take it to the dealer immediately... they reported back that it is operating "normal." Is this truly normal for this car? Thanks, in advance.
