Clicking noise from left front (driver side) wheel area
Old Jul 2, 2018 | 01:12 PM
drleadbasedpaint's Avatar
Default Clicking noise from left front (driver side) wheel area
I have a 2014 XC60 with a clicking noise coming from the front driver side wheel. 60,000 miles.
I took this to the Volvo dealer. There, they told me that the left CV axle inner joint is worn and may cause noise when turning or accelerating.
The solution was a CV Half Shaft replacement. This cost $908 US.
Old Jul 2, 2018 | 06:14 PM
tony1963's Avatar
I'm amazed that a 2014 model is already shot when I've sold 2001 models with the original axles. Oh well, nothing lasts forever.
The job is not that bad to do yourself. Here's an idea of what they cost on the aftermarket.
https://www.rockauto.com/en/catalog/...+assembly,2288
Old Jul 9, 2018 | 01:09 PM
JBxc60's Avatar
My 2010 needed a motor mount about 60,000 miles. I waited until I could hear it and then got both replaced. Yeah. I terms of wear and tear those parts seems to go out faster than on other cars. My indy mechanic seems to think it's the weight of the Volvo.
Old Oct 9, 2018 | 09:57 AM
Since replacing the axle, there's a new noise up front on the driver's side. It's kinda like clicking, but not all the time. Also, it's not the same as the axle problem.
Could it be the brakes?
Anyway, I'm hoping to put it off until *after* I change the transmission fluid.
Old Dec 5, 2019 | 06:32 AM
Michel Abdulahad's Avatar
Did you find the solution?
I'm having the same Problem. After CV joint replacement, a new kind of noise. Usually when I Start accelerating .
Old Dec 5, 2019 | 08:53 AM
Turns out, the other axle was also bad. I just had it replaced.
Most of the noise is gone now. However, something is *still* occasionally clicking.
Old Dec 5, 2019 | 09:48 AM
what brand did you use for the replacement axles? many after market axles are rebuilds so not the same quality as genuine volvo parts.
Old Dec 20, 2019 | 05:52 PM
The Volvo dealer did the work. I ***-ume that they used genuine parts.
cmonsters
2001-2013 model year V70
Jul 27, 2012 05:16 PM
Tango Hotel 57
May 12, 2012 04:59 PM
HAitch
Jun 4, 2011 03:04 AM
JP
Oct 18, 2009 11:10 AM
jmana
Aug 10, 2009 10:41 PM
