"Key not found" message while the engine is on
Old Jan 14, 2022 | 04:53 PM
Priju's Avatar
Default "Key not found" message while the engine is on
Hi All,
I own a 2021 Volvo XC60 T5 model. I am seeing a "key not found" message when the key is already inside the car (happens with both keys). This issue is mostly noticed when the passenger opens the passenger door or opens the trunk while the engine is on. If the car is turned off while the message is displayed, the car would not turn on again. The work around is to lock the car, wait for a few seconds and unlock the car again using the same key. I took the car to service. They change the batteries on both the keys but I still see this issue with both the keys. Any solutions/suggestions?
Thank you
Old Jan 15, 2022 | 09:26 AM
statman's Avatar
Reading the manual I see the following:
Old Mar 9, 2025 | 05:07 AM
Zebec's Avatar
Hey mate i have the same problem with my 2019 xc 60 volvo, while driving it says key not found ive changed the batteries but its same problem. How did you fix it?
tranquil94
Sep 17, 2023 12:22 PM
asaychow
Nov 20, 2019 07:43 PM
Marcy Gersh
Feb 20, 2016 10:15 PM
LeChasseur
Feb 16, 2010 10:07 AM
pyroted
Jun 9, 2009 09:34 PM
