New to Volvo: Cold start rough Idle and automatic start/stop disabled
I purchased a 2015 Volvo XC60 T5 with 70,000 miles about 2 months ago. Within a week, as I was cold starting the car for my morning commute, the car had a really rough idle, almost to the point of the engine dying, and then the check engine light came on and stayed on. Dealer diagnosed as #1 fuel injector, fuel pipe, and o-ring...all replaced. As I am unfamiliar to the features of newer cars, I realized after I got the car back from the dealer that it has the Automatic Start/Stop feature, but the feature is not operating. The "my car" computer says it is disabled due to "Electrical System." We checked the battery to make sure it is the correct one, as that feature requires a special battery. It is correct and has a sticker on it that says it is 14 months old. I have not returned to the dealer about the inoperable start/stop feature. But this morning, about 1 month after replacement of the fuel injector and related parts, I cold started the car again and had the same rough idle with near death and check engine light illuminated again. I am now curious if the two problems could be related? Has anyone had this issue before with the cold start? Thanks in advance....
its pretty rare for a fuel injector to fail. If you threw a fault code, then that injector should be replaced. The others are probably fine. Kind of like when an ignition coil goes bad - that doesn't mean the rest are "worn out". Injectors should last the life of the car so just a bit of bad luck here. Out of curiousity, what kind of fuel do you use (ie regular or premium?). Brand name premiums have extra detergents in them so if you like to run regular (most Volvos run fine on regular - they just make a few less HP), you should run some premium every 4th tankful or so - one tankful will clean the injectors and other fuel delivery components (you can google for Consumer Reports analysis on premium vs regular).
Towana Wilks (04-04-2020)
Johnny Volvo
11-27-2012 01:05 PM
