OBD port only read with engine running
Old Dec 20, 2024 | 05:37 AM
XC60T5's Avatar
Default OBD port only read with engine running
My OBD device only connects (via Blue tooth) to the car scanner app when the egine is running.
Is that normal?
Old Jan 9, 2025 | 05:45 AM
XC60T5's Avatar
Anyone?
Old Jan 9, 2025 | 01:07 PM
firebirdparts's Avatar
No
This stupid forum doesn't allow you to answer a yes or no question with the words "yes" or "no", so I have to type something more here.
Old Jan 10, 2025 | 10:58 AM
normally your OBD2 port gets powered with the key in position 2 but the engine doesn't need to be running (ie dash lights on, engine off). If you are not seeing power then you may want to check the fuse that powers the port.
ddbeckwith
Apr 21, 2012 04:47 PM
TonyS
Apr 26, 2010 12:17 AM
bestharry
Dec 16, 2008 11:41 AM
850GLTWAGON
Engine & Internal
May 22, 2006 12:35 AM
