Outside temp sensor
Old Oct 5, 2020 | 07:54 PM
E-Volvo-ing's Avatar
Default Outside temp sensor
This seems to be a common issue but I could not find a relevant thread here or a fix on google.
2012 XC60. 3.2.
Outside temp reads too high. I've heard there is a fault with the outside temp sensors. Does anyone have a fix for this?
Thanks!
Old Oct 6, 2020 | 09:20 PM
So after searching on-line I found that outside temp sensors can be a problem with almost all cars.
So I tested it!
The sensor is indeed located under the driver's side mirror and you can feel the little bump. After getting in my car and looking at the reported temp, I put my hand underneath it and even rubbed it a little and the temperature actually changed (almost) immediately to a lower tempurature!
The reading was still off, but at least I knew it was working and verified where it was located.
I do believe it does read the pavement temperature and this is what causes a reading that is higher than the ambient air.
Drivealot
Feb 27, 2017 11:22 AM
bobschwind
Sep 6, 2009 01:12 AM
mirek500
Feb 15, 2008 06:45 PM
mirek500
Feb 15, 2008 03:22 PM
hillfolk
Nov 26, 2006 01:05 AM
