Remove 2019 XC60 Center Console
Lost a piece of jewelry after it was placed on the drawer/cover in the center console above the shifter:
(Not an actual picture of my center console, just one I found while searching to give a better idea of where the jewelry fell)
I'm assuming I need to remove the whole center console to get underneath and retrieve what fell.
I couldn't find anything when searching the forums for a 2019 XC60, is there a guide for removing the center console?
PLEASE Let us know if a solution is found 🙏
A
This issue has been mentioned before but for the 2018 model. See here
A
A
Unfortunately the ring hadn't fallen below, and I suspect it's actually trapped up underneath behind the drawer:
I'm going to try to reach up there next but not feeling too confident that I'll be able to access what I need....
Thanks! This got both side panels off with ease:
I'd like to ask you, if you could please tell me if a dash cam powerbank would fit in this space? For example on this silver metal part from second picture? Or maybe deeper, on the right side?
The powerbank dimensions are 322mm x 89mm x 38mm, model from this link: https://www.power-core.co.uk/products/6200lfp-hw.html.
My Volvo has not yet arrived to my dealer, so unfortunately I can't check this myself and the powerbank will be shipped from UK to Poland, so I would like to avoid sending it back if it wouldn't fit.
I would really appreciate your help if that's possible.
Did you find it?
I’m having the exact same issue. Did you end up retrieving the jewelry?
