Replacing heater hose adapter.
Old Dec 22, 2018 | 02:11 PM
Bob1962's Avatar
Default Replacing heater hose adapter.
I am trying to figure out how to replace a leaking heater hose adapter on my son's 2015 xc60. Any help would be appreciated. How does it disconnect?
Old Jan 16, 2020 | 05:50 PM
dongo's Avatar
Hello - Did you ever figure this out? I have a leaking heater hose on the same vehicle (the hose's Volvo part number is 8641078) and the dealer quoted me $474 to replace it, although it costs $19. So obviously I'm going to try and do this myself. In case this is the same hose I thought you might have some insight.
Thanks
Old Jul 12, 2021 | 02:11 PM
tmackethan's Avatar
Hi, I have a leak from this same part. Were you able to replace it yourself? If so, do you mind sharing any tips?
Thanks, Tristan
Old Jul 13, 2021 | 08:26 AM
dongo's Avatar
Thanks, Tristan
Yes I was able to replace it myself but my memory of it is that 1) the hose was tough to locate in the car 2) there are different fittings on each end and 3) because of the fittings the old one was TOUGH to remove.
I guess the good news is that once the old one is off the new one is not that hard to install. I remember having to sort of disassemble the old one using pliers etc to get it off. Just be patient.
Good luck
mikde
Jan 21, 2014 01:12 PM
ycartf
May 6, 2013 11:19 AM
mpower916
Dec 30, 2012 01:12 PM
Ego Tripper
Jul 21, 2011 01:24 PM
Junkyardspecial
May 17, 2011 12:10 PM
