Suspension hissing noise when hitting speed bumps
Old Apr 23, 2020 | 01:44 AM
hhertz's Avatar
Question Suspension hissing noise when hitting speed bumps
Title pretty much sums it up.
I have tried recording it while driving, not the best audio quality though.
Trying to understand which suspension part contributes to this noise. Is it a strut compression/decompression?
Got a quote from a local shop for $1,700 (parts and labor) to replace all struts, and perform wheel alignment.
What's more important, is it something worth freaking out about? With windows down I can clearly hear the sound. Doesn't seem to affect handling.
Old Apr 24, 2020 | 05:38 PM
what year, mileage? Do the struts have any signs of oil leaking down from the top? Does the car still drive nicely or do you notice some instability? I think that some noise is to be expected from the strut/shocks compressing over speed bump. What I'd look for is oil leaking from the strut, thumping noises (indicative of a bad spring seat/strut mount or control arm/sway bar bushing).
Old Apr 24, 2020 | 06:04 PM
hhertz's Avatar
Year 2012, around 83k miles. I'll have to check for leaks. The car doesn't seem to sway from side to side. The noise is pretty noticeable, that's why I am concerned. I can even hear it simply on an uneven surface/terrain, but it is less obvious.
Old Apr 24, 2020 | 07:36 PM
It may be the dust boot or bump stop in the struts are rubbing. see if you can see a plastic guard inside the spring is in place (its supposed to keep dirt off the top of the strut/piston. If those are out of place, its not something that would be dangerous...
Old Apr 24, 2020 | 09:05 PM
hhertz's Avatar
To replace them you would still need to take out the entire strut assembly, right?
I kind of want to get rid of the noise, and if it is as cheap as replacing the dust boot or bump stop - I might go ahead and do it myself.
P.S. Appreciate your comments!
Old Apr 26, 2020 | 06:06 PM
well the dust boot is inside the spring at the top of the strut so you'd want to take a look to see if you can access without disassembly.
Old Apr 27, 2020 | 11:31 AM
hhertz's Avatar
During the recent oil change, when my car was on the lift we visually inspected strut assemblies, there were no leaks. Dust boots seemed to be holding in place.
I think if I get to the point of taking the entire strut out - I will be replacing it, considering the amount of labor to do that. Compressing springs, re-aligning the wheels, etc.
LiteWait
Dec 29, 2012 04:06 PM
Lars
Dec 5, 2008 06:22 PM
SAMM
Suspension
Jun 30, 2008 07:43 PM
cool_kyle_3000
Oct 21, 2007 09:31 AM
piston
Sep 21, 2007 05:55 PM
