water in footwell
Old Apr 25, 2021 | 07:43 AM
dougo01's Avatar
Default water in footwell
Hi: I have a 2015 XC60. Yesterday I was changing the in cabin filter and when I pulled back the carpeting I noticed the foam was wet.
This is on the passenger side. Any ideas on what this could be? Thanks
Old Apr 26, 2021 | 02:57 PM
Dingus's Avatar
If it smells like coolant, check your heater core and coolant level, which I hope isn't leaking on a 6 y old car, but you never know. Could also be a clogged drain on the passenger side
Edit: https://volvoforums.com/forum/volvo-...0-xc60-105635/ check here for other possibilities too
Old Apr 26, 2021 | 03:45 PM
dougo01's Avatar
thanks Dingus...it is not coolant just water. So I'll check the A/C drain as well as any other drains I can find. Thanks again
Old Apr 26, 2021 | 03:54 PM
dougo01's Avatar
thanks Dingus...it is not coolant just water. So I'll check the A/C drain as well as any other drains I can find. Any thoughts on where it might be? Any help greatly appreciated.Thanks again
Old May 24, 2021 | 02:37 PM
Blanch Reyna's Avatar
Default Windshield leaks on XC60's since 2010
Check your seal on front windshield. We had water on our knees and hands dripping and it was from a leak on the front drivers side. But it might be a leak on passenger's side. Let me know what you found
Old May 24, 2021 | 03:25 PM
dougo01's Avatar
hi Blanch:
In late April I removed the shroud that meets the windshield at the front. Actually there is the windshield, a shroud and a small plastic ridge that separates the windshield from the shroud. It had fallen away. anyway I was able to reattach it with the help of silicone and it seems to be fixed. After I ensured it was not from the a/c condensate the front windshield seemed to be the most logical place to look and voila...problem solved. Thanks
bmxc60
Dec 28, 2021 02:14 PM
platform
Jan 8, 2020 03:02 PM
ABVO850
Feb 29, 2012 07:06 PM
john knox
Jul 31, 2010 12:54 PM
Bill Parecki
Dec 14, 2008 09:16 PM
