wheels
Old Sep 11, 2020 | 12:00 PM
XCTim's Avatar
Default wheels
I currently have a 2011 XC60 D3 RDesine front wheel drive running on 18" rims, I'm thinking of changing the rims to XC70 ones has any body done this and if so what size tyers did you put on.
Old Sep 11, 2020 | 01:00 PM
The xc70 wheels from 01-07 have a larger hub bore, you would need hubcentric rings to make those roll without vibration, the hub bore is the same as yours on 08+ xc70 wheels - what's the part number on the wheel you are looking at?
Old Sep 11, 2020 | 02:31 PM
wheel-size.com is a good ref site for wheel specs. As you will see, 2010+ years (and gen2 s40s) use the smaller center bore. You can use this to see what offsets and tire sizes were standard for various model/years.
Old Sep 13, 2020 | 02:10 AM
XCTim's Avatar
Found these, will they fit.
https://www.ebay.co.uk/itm/133496290046
jameswblacker
Oct 3, 2017 07:52 PM
thesam1984
Dec 21, 2015 10:20 PM
nilo
May 1, 2012 09:44 PM
ari33
Sep 3, 2009 07:23 PM
johnboy1967
Dec 3, 2004 10:44 PM
