Alarm goes off randomly
Old Nov 10, 2019 | 05:42 PM
John Wood's Avatar
Default Alarm goes off randomly
The alarm on my 2004 XC70 AWD goes off randomly- usually pretty soon after I lock the car and leave it.
Here are my DTCS codes:
BCM NOT CHECKED
SRS READY
TCM CHECKING
ECM DTC SET
DEM READY
AUM DTC SET
CEM DTC SET
DIM READY
DDM DTC SET
CCM CHECKING
PDM DTC SET
PEM DTC SET
REM CHECKING
SWM READY
UEM DTC SET
What can I do to fix it?
Bonus: What can I do to fix BRAKE FAILURE STOP SAFELY?
Thanks,
John
Old Nov 11, 2019 | 11:05 PM
those are telling you there are codes that are set. Start by getting a code reader that can read both chassis and ABS codes then note the codes and clear them. after a drive do a second scan to see what has reset. Sometimes when there are that many codes it can be an indication of a voltage issue or a connectivity issue - at some point in time if the system voltage dropped below the acceptable threshold and the computers may set false positive codes so best to clear them. If there's a truly bad device, the codes will reset pretty straight away.
Old Jul 25, 2020 | 02:01 PM
Stewart-18's Avatar
To check codes:
l-lilyblade
Sep 19, 2017 05:01 PM
ScottyJ
Sep 28, 2012 08:51 AM
dcarlson12
Nov 3, 2008 01:52 PM
ivanczar
Sep 17, 2008 05:21 PM
fivespeed
Sep 24, 2007 10:06 PM
