All kinds of Beautiful White Smoke
Old Apr 23, 2010 | 04:12 PM
Volvos3's Avatar
Default All kinds of Beautiful White Smoke
So My 99 XC70 Started Blowing steam out of the engine about a mile from home! It just got into the red when I pulled into my driveway! Now it Pours out this beautiful whit smoke From the tail pipe when I start it! Also the Engine oil has turned in to this lovely really runny lighter shade I think I must have a bad Engine mount
What do you think? Can it be Fixed?
No Seriously though Do you think the head may be warped? I know the HG is blown. It was only in the red for a sec. However it did sit there with the fan on for a while.
Anyone have instructions on Head Removal? Bolt pattern Removal ETC?
Any help would be Much appreciated.
Old Apr 24, 2010 | 07:45 AM
Yes I will bet the head is warped. Usually the head is what warps and causes the issue. The headgasket itself usually does not blow the head warps. But unless it has been done a couple of times already you should be able to have it shaved and reinstall it and go.
I think there might be a few posts about doing the job.
Old Apr 30, 2010 | 04:13 PM
Volvos3's Avatar
Oaky guys I am going to attempt to pull the head off this weekend and check it out.
Btw what order should i take the head bolts out and when i put them back in what order and how tight?
Old Apr 30, 2010 | 09:55 PM
To remove the headbolts start in the center and work your way out.
When you are ready or this weekend I will post the rest for installing it.
Old May 3, 2010 | 04:48 PM
Volvos3's Avatar
I Did it from Out to In. Thats how I read to do it before you posted. It says to do in to out to put it back on. HG is deffinatly blown Water win Cyl 234 Mostly 3. I need to get a straight Edge to Check the head to see if its warped. Will a Long Steel Speed Square work?
Old May 3, 2010 | 09:35 PM
That should work fine. I will bet it is warped.
I will try to find the specs sheet with order and scan it and post it.
Old May 4, 2010 | 12:25 AM
Volvos3's Avatar
Ugg Dont say that! Instead say good luck you will be fine I hope it works out. Thanks for the hel though!
Old May 4, 2010 | 09:50 PM
Sorry I just have not seen a head yet that did not need to be shaved.
Old May 8, 2010 | 03:46 PM
Volvos3's Avatar
Isnt there danger of cracking or breaking a Cam if I get it shaved? sure it makes the bottom flat but itf the head is warped wont the rest of the head still be warped?
Old May 8, 2010 | 03:58 PM
You will be fine. I have never had one crack before!
Old May 12, 2010 | 05:08 PM
Volvos3's Avatar
Got the head back today and its straight!
Did I mention my wifes 940 blew a HG as well?
Its Straigt too!!!!
Before
After
Old May 12, 2010 | 09:31 PM
Were they straight before having them machined?
I can believe the 4 cylinder one. But the 5 cylinder I have not seen one straight as of yet.
But then maybe I have now.
Old May 13, 2010 | 11:59 AM
Volvos3's Avatar
He said it was. I told him I diddnt want him to do it unless he called me first.
Old May 13, 2010 | 09:18 PM
Well all in all you are good to go on putting it all back together.
Old May 31, 2010 | 01:47 PM
Volvos3's Avatar
Thanks for the help It has been up and running for 2 days now.
I have put about 200 miles on it without issue.
Some pics my wife took.
Old May 31, 2010 | 05:11 PM
Glad all is good now!
matt01
Jul 23, 2012 11:12 AM
Capo Cam
Feb 19, 2008 11:09 AM
rorym1980
Sep 29, 2007 12:21 PM
ouyangcui
May 9, 2007 10:31 AM
92volvo960
Nov 1, 2006 11:10 PM
