Blown Engine
Old Jan 31, 2007 | 10:24 PM
mustang126's Avatar
Default Blown Engine
Hi, I have a 1998 V70 XC with a Bad B5254T engine in it. I want to replace it with a B5234T4 Engine that I already have. Does anyone know if this will work ok ???Will welcome any advice..Thanks,Jeff
Old Feb 1, 2007 | 08:37 PM
Default RE: Blown Engine
I believe it will work fine in there.
Old Feb 1, 2007 | 09:20 PM
mustang126's Avatar
Thanks for info...No computer changes ????
Old Feb 1, 2007 | 10:46 PM
It really shouldn't matter.
You are just installing the motor.
The motor isn't out of a 1999 or newer is it?
Old Feb 1, 2007 | 11:29 PM
mustang126's Avatar
Might be out of a 99'...Any problems with that ?
Old Feb 1, 2007 | 11:32 PM
Does it have VVT? (Varible Valve Timing)
Old Feb 2, 2007 | 01:15 AM
mustang126's Avatar
Where would it tell you that... On the engine code tag or ???
Old Feb 2, 2007 | 08:29 PM
If you look at the Cam pulleys one will look really fat and the other will look skinny.
Also if it has VVT there will be a valve that screws to the top of the cam cover.
The timing cover will also look different.
shai_kino
Aug 20, 2014 06:45 AM
pdunn
Oct 26, 2008 07:53 AM
Maine850
May 31, 2008 12:46 AM
jayad
Feb 11, 2006 04:38 PM
VolvoJimmy960
Apr 20, 2005 01:51 AM
