Brake Air Leak
Old Aug 8, 2011 | 08:20 PM
Tags's Avatar
Default Brake Air Leak
Hi guys,
The new to us Volvo V70XC has an air leak when your foot is lifted off the brake pedal. It happens about 50% of the time. I will brake and then after i let my foot off i will get a hissing sound for a little while. I did some searching and found some posts but they all seem to indicate a hissing sound when they apply the brakes not when they release them. The leak also affects the cars idle when coming to a stop, it lurches forward a little right before stop when the rpm's are at there lowest when its in gear.
Is my problem the brake booster or just a leaky hose?
Thanks,
Old Aug 21, 2011 | 07:53 AM
VTBricked's Avatar
Check your vacuum connections for the brake booster. You may find one loose. Have someone press/release the pedal while you're looking/listening.
2008XC70
2001-2013 model year XC70
Dec 20, 2017 03:07 PM
ROBLU540
Feb 20, 2009 07:59 PM
1999S80T6
Dec 16, 2008 04:54 AM
kartman01
Nov 30, 2005 10:00 PM
kartman01
Nov 26, 2005 09:47 AM
