Climate Control Fuse
Old Jul 11, 2010 | 03:33 PM
NJBV70XC's Avatar
Default Climate Control Fuse
I have a 98 V70 XC. I was driving down the road and the a/c stopped blowing cold air. Upon inspecting the car I noticed that the Climate control/diagnosis fuse was blown. I replaced the fuse and it blows immediately. I am not sure what would be sending the extra power to blow the fuse. The blower is working fine and the compressor seems to be working fine as well. I am lost here as to what would be causing the fuse to blow.
Old Jul 11, 2010 | 05:54 PM
If you unplug the A/C comp. does the fuse still blow?
Old Jul 11, 2010 | 07:06 PM
NJBV70XC's Avatar
The fuse did not blow when I disconnected the a/c comp. Could this be b/c there is no refrigerant in the system or b/c the comp is dead?
Thanks
Old Jul 11, 2010 | 07:29 PM
The compressor clutch is shorting out causing the fuse to blow. That is what it sounds like is happening.
ajaybali1
Jan 31, 2011 05:49 AM
tangox
Dec 29, 2008 01:27 PM
mischief4l
Sep 2, 2008 07:13 PM
jfikentscher
May 31, 2006 09:58 PM
watson6033
Feb 24, 2005 12:08 AM
