Dead CEM. any ideas?
Old Dec 25, 2008 | 08:09 AM
nev70xc's Avatar
Default Dead CEM. any ideas?
So here's my problem.MY friends 2001 v70xc has numerous electrical problems.No power at driver info module when key is turned on,no power windows or lock controls.the engine cranks but won't start.we reset all body control modules.It appears the Central Electronics Module is not powered up.I was told that by turning on the hazard lights and operating a rear window with a rear door switch the window should work indicating power at the CEM ,it does not work.ckecked ignition switch and it is good.checked for power at CEM pin A5 No power.Any idea's??
Old Dec 25, 2008 | 10:53 PM
Default RE: Dead CEM. any ideas?
All fuses and battery connections under the hood in good condition?
Old Dec 26, 2008 | 08:46 AM
nev70xc's Avatar
Fuses are good and battery connections are also good.Found what looks like a fuse link on the wire print going to ck thatnext.
Old Dec 28, 2008 | 10:53 PM
Psaboic's Avatar
If fuses are good, and you have access to a wiring diagram, I would check all connections and then start tracing the power flow along the various wires. You should find your porblem.
Good luck!
Old Jan 6, 2009 | 08:06 AM
nev70xc's Avatar
Just an update if anyone should ever have the same problem.It turns out the CEM does have power,All my problems are due to a damaged CEM,I first thought the low speed bus was dragging it down but now it looks like the CEM is no good( bad solder joints ? )Anyhow off to the dealer.thanks for all you suggestions.
JenniferXC70
2001-2013 model year XC70
Oct 25, 2022 10:46 PM
04arghh
Aug 23, 2007 02:44 PM
jonnycd
Jun 12, 2007 06:12 PM
JasonCase
Mar 11, 2007 01:46 PM
seattlevolvoguy
Jan 1, 2006 05:31 PM
