Front suspension woes.
![Question](https://volvoforums.com/forum/images/icons/icon5.gif)
We have a 2002 XC70 with about 110 k miles on it. About two weeks ago, we replaced the struts, springs, and mounts. We noticed a "list" in the rear, and sure enough we had a broken spring. We also had a "clunking" or "rattling" in the front suspension over rough roads, which is still there. It sounds like the sway bar is slapping the bottom of the car. We now have a new noise that happens when you turn the steering wheel at VERY low speeds or a dead stop. This one sounds like a knocking.
I have done some searching and found it may be the steering stops are binding? As for the klunking over bumps, well I have seen the gammit including bearings, bushings, tie rod ends, strut mounts, ball joints, and everything in between. I am not going to spend an arm and a leg to replace everything, so if someone has some more definite answers, it would be greatly appreciated.
