Suspension woes
Old Apr 19, 2012 | 12:18 AM
91shelby's Avatar
Default Suspension woes
well after hunting down a wierd knocking i came to find that my strut had gone bad and could be wiggled side to side replaced that with a spare i had and it was good had it aligned the next day and now its starting to go bad again what would cause 2 struts to fail like this.. both were new bilstiens the old lasted 1 1/2 years this new one even less.....
Old Apr 19, 2012 | 10:51 AM
Mad Matt's Avatar
Hey Matt, How are the rest of your suspension components?
And do you still have your Gmail account? I've been trying to email you lately...
Old Apr 19, 2012 | 01:18 PM
91shelby's Avatar
how about sub frame bushings? how often do these go bad? i know they are original and what cause and effect could they have? also whats the best way to replace them with out a lift
Old Apr 19, 2012 | 08:44 PM
jasenklems's Avatar
you could check the lower control arm bushings... that is what is bad on mine as well as the struts and a sway bar end link
Old Apr 20, 2012 | 12:31 AM
boxpin's Avatar
Thats not right. The only thing I can think of is a spring not seated right causing the shock to be constantly trying to bend because it does not have the correct load alignment. I am just making this up but it seems to make sense if it was alway wearing on one side.
Old Apr 20, 2012 | 11:07 AM
91shelby's Avatar
heres the thing too the tires have worn evenly... spring seat is seated correctly into the strut mount.. ittl pull severely to the left once and awhile sometimes slightly and sometimes wont pull at all and steer straight.
Old Apr 22, 2012 | 12:44 PM
91shelby's Avatar
it does it the worst when under load specially going up a hill
Old Apr 22, 2012 | 01:44 PM
Turkey_Sandwich's Avatar
Maybe take it back to the shop that aligned it and describe the problem? Maybe their techs could look at it and figure what's going on.
If something was that badly worn, they should have caught it when it was on the rack to start with.
itsnota2ma
Dec 17, 2013 07:40 PM
GilliamII
May 10, 2012 09:08 PM
Torkk
May 28, 2010 05:02 PM
medufour
Jul 3, 2007 07:48 PM
sghokie
Sep 26, 2006 01:35 AM
