How do I remove my driveshaft?
Old Apr 5, 2008 | 05:06 PM
johnhon's Avatar
Default How do I remove my driveshaft?
I'm having a difficult time removing my driveshaft on my XC. (I need to replace the u joint). I can't get to all of the 6 allen screws that hold each end the shaft to the transmission and rear end and I can't rotate the driveshaft to access them. Am I missing something simple? I have the entire car up on jack stands to have more working space underneath. I thought spinning the wheels would rotate the shaft but no such luck. Thanks for any help.
Old Apr 5, 2008 | 09:03 PM
Default RE: How do I remove my driveshaft?
Is it in Neutral?
It is something that gets overlooked very easy.
Old Apr 6, 2008 | 10:18 AM
johnhon's Avatar
Thanks Tech. That worked and I managed to get the front coupling off, and I got the back flange off, but it seems like something else is holding the rear into the torque tube. Do I need to bang on it or is there something else I am missing?
Old Apr 6, 2008 | 10:27 AM
The viscous coupler also has screws holding it to the rear diff.
Remove the torque tube then the viscous coupler as well.
MoneypitC70
2001-2013 model year XC70
Oct 26, 2014 08:37 PM
dragon19a
Jan 15, 2007 09:19 PM
lotusing
Jun 14, 2006 11:58 PM
Walter J.S.
Apr 16, 2006 10:12 AM
Eli_T
Jul 1, 2005 03:26 AM
