How to R & R sunroof Siren module
Old Oct 8, 2010 | 08:12 AM
49willard's Avatar
Default How to R & R sunroof Siren module
I recently had my 2004 XC at a dealer for a visit to Vida for erratic window operation (see post below). I also had a failure to open on the sunroof. The dealer found codes uem-0004 and 0005 and test of the siren module determined the module to be failed. Estimate to R and R was $460. I try to do as much as possible myself. Where is the module, what does it look like, is a used module a good idea, and what are the pitfalls of me doing the R and R? Will it need to go back to the dealer (vida again?) to set operation? Any advice greatly appreciated.
Bill
Edit:
I did a search online and did find some additional info. The R and R that I found was for a S80 which had the module in the right front fender well which is accessed after removing the inner fender. Is the 2004 XC70 the same?
Old Oct 21, 2010 | 02:46 PM
jim_brown's Avatar
I'm having the same problem, '03 xc - alarm would go off at random, I pulled fuse 38 and then the sunroof would stop working, now when I replace the fuse it keeps blowing - after googling/etc. I found the alarm siren and sunroof are on the same circuit -
Apparently, with age, the battery inside the siren module begins to leak acid onto the circuit board in the siren, which is causing the fuse to blow. wonderful
I found this DIY - looking at the comments of this page it seems to be the same for xc's
http://www.matthewsvolvosite.com/for...p?f=11&t=17479
I called a local indy shop, they quoted $150 labor to replace (plus parts), part at the dealer is $241, I found one online for 185 (w/shipping) - seems straight forward, I'll attempt myself
http://volvowholesaleparts.com/partl...subcat2=159752
good luck, if you replace, just be sure to do the lock/unlock with key three times as it resets everything, don't think there's a need to have to go to dealer
csanchez
Mar 18, 2013 05:43 PM
02volvo
Nov 25, 2012 03:44 PM
agoldberg2
Jul 25, 2010 03:33 PM
huzzsaba
Apr 2, 2009 05:35 PM
vegasjetskier
Aug 30, 2008 04:19 PM
