2001 S80 T6 Siren Module Location?
Old Aug 30, 2008 | 01:14 PM
vegasjetskier's Avatar
Default 2001 S80 T6 Siren Module Location?
Does anyone know where the siren module is located on the 2001 S80 T6? Are the batteries replaceable? I'm showing the "Alarm System Service Required" message and want to check out the module. Thanks.
Old Aug 30, 2008 | 02:26 PM
Default RE: 2001 S80 T6 Siren Module Location?
It doesn't have any batteries.
It is located in the R/F fender. You would have to remove the inner fender liner to get to it.
Old Aug 30, 2008 | 02:37 PM
ORIGINAL: tech
OK, thanks. Someone told me it had NiMH batteries in it and someone else said it was in the engine compartment. Lots of misinformation out there. Thanks again.
Old Aug 30, 2008 | 02:40 PM
Sory to say but it needs to be replaced. We replace alot of them.
Old Aug 30, 2008 | 02:48 PM
Is that a plug-and-play replacement I can do myself or do I need a Volvo dealer toload software? Thanks.
Old Aug 30, 2008 | 03:02 PM
No software but it should be recalibrated by Dealer it Indipendant shop. You can install it them have them calibrate.
Old Aug 30, 2008 | 03:05 PM
OK. Thanks very much!
Old Aug 30, 2008 | 03:06 PM
Your welcome.
Old Aug 30, 2008 | 03:44 PM
You wouldn't happen to know what the AC freon pressures are supposed to be, would you?
Old Aug 30, 2008 | 04:19 PM
Not right off hand I will have to look them up.
wemxm10
Oct 22, 2024 03:52 PM
csanchez
Mar 18, 2013 05:43 PM
02volvo
Nov 25, 2012 03:44 PM
49willard
Oct 21, 2010 02:46 PM
agoldberg2
Jul 25, 2010 03:33 PM
