Major Help Needed!!!!
Old Nov 28, 2011 | 07:55 PM
thundering89's Avatar
Default Major Help Needed!!!!
Hi, I need some major help. I work for Sears Auto Center. Ive never worked on a Volvo before and the VVT is really confusing me. Long story short is that the tech that was working on it isnt here anymore. He was replacing the cam seals and timing belt on an 05 Volvo XC70. My question is, how do I re install the VVT cam gears? The crank is at TDC. Ive search for hours and hours trying to understand the VVT gear but all I can find is the removal procedure for the belt. I would assume it would be reverse for the install. The information I found states to turn the crank clockwise until the timing mark line up. Then turn 1/4 turn more then turn counter clockwise back to the timing marks. Would that be the same process I do for the cams? Any help or information would be appreciated.
arobin07
Oct 14, 2014 10:29 AM
Galaxy850Sunny
Jun 23, 2014 04:56 PM
1990TURBO740
Mar 22, 2006 08:26 PM
jayad
Dec 28, 2005 01:25 AM
bluejohn
Engine & Internal
Dec 1, 2005 10:47 PM
