O2 Sensor connectors -which one?
Old Nov 18, 2010 | 08:33 PM
VTBricked's Avatar
Default O2 Sensor connectors -which one?
I'm ready to connect the O2 sensors from the exhaust, and I'm looking at the two connectors on the chassis. Which connector is for the pre-cat O2 sensor and which one is for the post-cat one? It looks like the connectors are the same.
Old Nov 18, 2010 | 09:14 PM
One should be black and one should be gray.
Old Nov 19, 2010 | 05:22 PM
VTBricked's Avatar
Thanks Tech! I supposed if wasn't pissed off like a deranged psychopath after wrestling the angle drive back onto the trans because I couldn't re-attach the down pipe without doing so.....I might have seen it myself.
Old Nov 19, 2010 | 08:29 PM
Did you upgrade the exhaust?
Old Nov 20, 2010 | 04:10 PM
VTBricked's Avatar
No - I was "simply" swapping transmissions. It's a fairly low miles (130k) '98 that was in decent enough shape to fix. And I found a decent donor/parts car that wasn't in decent enough shape to fix. This will be a flip car to help get 3 kids through college.
Old Nov 20, 2010 | 06:36 PM
Oh ok was just wondering.
Drechtaber
Jan 8, 2012 07:47 AM
iron_rhino
Dec 17, 2008 11:57 AM
Paudman
Apr 3, 2008 07:09 PM
ko_kidd
Aug 25, 2006 08:53 PM
jcmartin
Aug 12, 2005 11:20 PM
