ODB II Check Engine Codes
Old 03-02-2010 | 03:06 PM
daharleyrdr's Avatar
Smile ODB II Check Engine Codes
On the advice of some forum member's I purchased an OBD II Scanner tool from "DIY Diagnostics" It reads the code and also give a brief explanation! Great for $45. I had a check engine light come on on my 2000 V70 XC, The light went out itself, when the tool arrived in the mail, LOL!!I checked the stored codes and two came up. Can anyone explain what they are in layman's terms and how to fix the problem associated with the code?
The first Code PO460 Fuel Level Sensor Circuit
The second Code PO422 Main Catalytic efficiency below threshold Bank1. Now this code came up before and I had the mechanic clear it so I could pass inspection at the inspection station and the car passed. As to replace the Catalytic converter is between $1000-$2000.
The car Car runs fine! Any help would be appreciated. Thanks Bill
l
MarksS60
01-09-2009 05:27 PM
MNVS60
02-01-2008 07:03 PM
KubilayK
12-31-2007 05:29 PM
JimKW
10-05-2007 12:32 PM
linusvolvo
11-16-2006 12:28 AM
Quick Reply: ODB II Check Engine Codes
