Pulled 2 codes with ODB II
Old Nov 15, 2006 | 05:13 PM
linusvolvo's Avatar
Default Pulled 2 codes with ODB II
Went to Autozone to find out why my check engine light and flashing orange arrow was on my 97 850R and found the following codes:
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0500 something about a speed sensor malfunction (aka cruise control sensor)
Any ideas? I ordered both parts hoping that I can fix it myself, but any help would be EXTREMELY appreciated!
Old Nov 15, 2006 | 09:08 PM
Default RE: Pulled 2 codes with ODB II
Did they clear the codes?
Did they come right back?
Old Nov 15, 2006 | 09:42 PM
linusvolvo's Avatar
I did not try clearing the codes, since the guy who sold it to me said that this was a problem. I totally regret moving forward with the purchase, but no options now. I think he cleared it first by just disconnecting the battery, but then it came back. Plus the orange arrow and econ light keep flashing. I need to get the check engine light off in order to pass the smog test here in Cali [:@]
Old Nov 16, 2006 | 12:28 AM
You need to try to get the engine and trans codes cleared and see if they come right back.
Most of the time just disconnecting the battery won't work.
Did they only pull codes from the engine?
Or did they pull tranny codes?
You might just have a bad PNP switch. For the arrow flashing.
Replace the o2 sensor the fault is in the preheating circuit.
MarksS60
Jan 9, 2009 05:27 PM
chimmychong
Apr 2, 2008 08:34 AM
MNVS60
Feb 1, 2008 07:03 PM
KubilayK
Dec 31, 2007 05:29 PM
JimKW
Oct 5, 2007 12:32 PM
