oil in the water
Old Jul 31, 2010 | 10:00 AM
kmellott's Avatar
Default oil in the water
I recently replace the head gasket, 1500 miles ago, during a valve replacement, now I have oil in the water. No water in the oil. Starts and runs fine. 190,000 miles on vehicle. Could this be a breach in the radiator? Original radiator. I will do a compression test. Back when I replaced the head gasket, should I have re-tightened the head bolts. I tightened them as outline in the head kit. Years 25 ago when working on diesel tractors, we re-torqued the head bolts after several hour of operation.
Old Jul 31, 2010 | 10:42 AM
No need to retorque these head bolts.
What year is it?
The cooler in the radiator (if a 98) might have gone bad. Or the cooler on the back of the oil pan(99 and newer) might be bad.
Or it could also be the transmission cooler.
Old Jul 31, 2010 | 03:59 PM
kmellott's Avatar
1999 V70 AWD 2.4 turbo
Old Jul 31, 2010 | 04:24 PM
Then you should have the oil cooler on the back of the oil pan.
Does it look like strawberry milk or more like milk in the coolant bottle?
Old Aug 1, 2010 | 08:21 AM
kmellott's Avatar
It is engine oil. It is chocolate in color. Oil level has dropped off the dipstick. I will check the oil cooler. Is that a common problem. How do I check for a breach inside the oil cooler.
Old Aug 1, 2010 | 08:38 AM
Best way to check would be to remove it and pressure test it.
Old Aug 4, 2010 | 10:46 PM
kmellott's Avatar
Pressure tested and air moves from the oil side to the water side. Needs replaced. What is the best way to get all the oil out of the coolant system? I flushed it several times. Is there any dissolving agent to add, then flush?
illfrom
Mar 7, 2010 09:15 AM
supernicguy
Jan 22, 2010 06:21 PM
s70_007
Dec 19, 2008 09:26 AM
mkelly85
Jan 31, 2008 02:05 AM
flapper
Oct 22, 2007 05:56 PM
