P3 high beams LED conversion
Hey everyone! New here with a 2009 XC70 T6 i just bought. I have the HID headlights and i was looking to convert the high beams to LEDs since the low beams are kinda brighter. So got a nice set from Amazon but seems the socket is quite different from what i was expecting... Anyone here made the switch on the high beams that has advice to fit them on? They just won't hold the new lights.
Thanks!
Thanks!
So what you think are the high beams (the inner bulbs) are the daytime running lamps (if turned on)
This is only valid for cars with HID bulbs - if you have H11s - you do not have HID bulbs and you do have a separate bulb for high beams.
My 2008 V70 has the active bi xenon headlamps in the outer headlamp positions.
The bi xenon are on when the engine is on as they are the daytime running lights as well. When the high beam is activated the bi xenon go to high beams and the inner quartz halogen high beam bulbs turn on.
Don't know if they work differently in the US. I would double check your owners manual.
bcolins
2001-2013 model year V70
11-22-2013 09:49 AM
