Passenger door mirror replacement
Old Dec 2, 2007 | 09:45 PM
jose57's Avatar
Default Passenger door mirror replacement
Wife backed into the garage door and destroyed side mirror. Any tips on how to remove it?
Old Dec 3, 2007 | 08:48 AM
Eric J's Avatar
Default RE: Passenger door mirror replacement
If it is just the mirror itself that is broken, pull out the remains and snap in another. If it's the whole housing, you may be able to salvage it by pressing it back together and replacing the mirror. If not widen the garage door and screw on a side mirror from a 1994 Peterbilt 379 Ext.(Just kidding)
Old Dec 3, 2007 | 10:14 AM
jose57's Avatar
What's broken is the housing assy, the motor base and what holds the mirror and the mirror,
She most of been noy paying attention has she backed out.
Old Dec 3, 2007 | 01:37 PM
Eric J's Avatar
Check the local auto salvage yards ,to see if the have a mirro assembly(preferably in your color). If not try here: http://www.usedpartslive.com/catalog...28is&cat=h
Then pop off the small panel behind the mirror,on the interior side of the door. You'll find the screws that hold it on there.
Old Dec 3, 2007 | 05:37 PM
You will also have to remove the door panel to unplug the mirror plug.
jipsy
Jan 22, 2012 06:00 PM
dafemrite
Aug 13, 2011 01:12 AM
dvc100
Oct 1, 2009 04:58 PM
EAS1
Oct 13, 2007 05:51 PM
